Results 1 to 10 of 15
- Feb 2017
- 210
June 24th, 2019 11:49 AM #1yung water pump para lumakas ung tubig pwede ba gamitin un gagawing portalble pressure washer?
June 24th, 2019 11:57 AM #2
June 24th, 2019 12:03 PM #3
Yes and no.
Yes, if it has a pressure tank, then water from it will be pressurized... somewhat. If 40 PSI (typical pressure of residential booster pumps) is good enough for you.
No, because, it's not purpose-built for pressure washing. For one, it still needs a nozzle to go with it, to which the pressure is likely not enough, and these pumps will come out more expensive.
On the other hand, a proper pressure washer already includes everything you need. Suffice to say, it's built for the sole purpose of pressure washing. It can produce about 1,000 PSI of pressure, more portable, and cheaper.
- Nov 2009
- 3,507
June 24th, 2019 01:08 PM #4
- 54,226
June 24th, 2019 01:29 PM #5puede kung puede.
i suppose that's because you already have the the pump.
do you have the other parts, like the tubings?
then you'll have to assemble it pa.
hassle, unless you enjoy DIY.
just perusing olx, there are several for-sale ones, ready-to-use.
our house is supplied by a pressure tank. it is easy for us to connect the garden hose, and do some pressure-washing if we want to. the pressure is not strong (40-60 psi), "but it suffices".Last edited by dr. d; June 24th, 2019 at 01:31 PM.
- Jun 2005
- 3,774
June 24th, 2019 03:49 PM #6Pupwede naman. Ganun gamit ko. Yung hose ko is connected to a faucet sa pressure tank. So i get pressurized water sa hose.
Sent from my MI MAX 2 using Tapatalk
June 24th, 2019 05:26 PM #7
pwede provided kaya ng nozzle mo given pressure ng water pump mo. baka kaya nga ng hose but maghiwa-hiwalay nozzle mo talsikan ka pa.
June 24th, 2019 10:55 PM #8
Pwede, ganyan lang gamit ko before.
1. The pressure tank needs to be by-passed. Ibig sabihin yung papunta sa pressure tank dapat may valve na sarado tapos yung water papunta sa hose e meron ka tee before the valve.
2. Pwede yan continuous, mababa lang pressure nyan. I used a 1/2 hp pump before the pressure was only maximum 150 psi.
3. Kaya ng garden hose at garden nozzle ang 150 psi. Ang problema lang yung hose connections mo. Paminsan-minsan itatapon nya yung nozzle pag di mahigpit yung hose.clamp. So yun lang talaga ang problem nyan pag maluwag ang clamps.
PERO, since ang price ng 1/3 hp pump ay P3500, add mo pa price ng good quality garden hose and nozzle plus very good quality hose clamps, E MAS MURA PA BUMILI KA NA LANG NG PRESSURE WASHER P4k lang.
- Nov 2009
- 3,507
June 24th, 2019 11:55 PM #9^ And the inconvenience of wiring and earthing the motor, dipa portable. lol
- Oct 2012
- 4,851
September 13th, 2019 04:33 AM #10I saw some seller sa shopee... around php5,000
Bosch
Self priming
110 bar
1300 W
This is good since pwede na hindi direct sa water faucet ang source, sa water bucket or tank pwede na...
Anybody tried ? Or ano alternative nyo? Plan to buy on December...
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
