Results 11 to 14 of 14
October 26th, 2015 02:19 PM #11
- Aug 2012
- 2,767
October 26th, 2015 03:01 PM #12
- Dec 2018
- 5
December 17th, 2018 06:03 PM #13I use the ones at Wilcon on our black and white cars. I wipe the scratch with a very small amount of lacquer thinner to remove wax. (That's a very small amount, just a dampened cloth ) then I rub on just one line of it and wipe it lengthwise with my finger to remove excess. Do this a couple of times. Let it dry 1 day. Then take 3000 grit wet sandpaper and rub just a little, then buff with scratch remover or polishing compound. It will almost disappear. Be careful not to sand too much. It will work the same on other colors just get as close a match as possible. Less is more! Put on less, sand less, buff less= a better job.
high idle RPM at engine start
