Results 1 to 20 of 1418
Threaded View
    Jan 2008
    #21
    You're welcome bro, To answer your question If I do FEA or Finite Element Analysis, No I'm not at that level yet. But I do believe that there are talented Mechanical or Structural Engineers from the rosters of DLSU or any good engineering school for that matter who are capable of undertaking this task. AFAIK its basically used for Stress Analysis and also has broad applications in the automotive engineering field especially with regards to safety of the elements or parts of a car. I'm still just a newbie in this whole car design thingy and basically am still at the research stage which I'm quite good at. If you want free 3ds car models follow these steps..
    1). Go to u*******.com
    2). Download their client software then install it.
    3). Run the u******* client (you will notice it's green u icon with a circle at the lower right hand corner of your desktop).
    4). Go to Btjunkie.org and at the search bar type 3ds models the press the search button and you will get a list in the results panel. Double click the ones with a green bar at the meter found on the right side of the panel. Those ones are the active files and the ones with red bar are basically inactive and cannot be downloaded. Just confirm the ******* download instructions with the Ok button. When you switch over to u******* client you will find its already downloading. Right click the file being downloaded to give you more menu options like priority and speed etc. When its finished you can just double click the file to open it or you can open its containing folder. In case you're wondering, I'm an Industrial Engineer so my forte is more on the production side of things but I've also had some 3d AutoCAD modelling background. Hope this helps.
    Last edited by TambayBlues; February 12th, 2008 at 03:55 PM. Reason: Spelling and change of terminology
Tsikot.ph PHUV Prototype
