Results 1 to 10 of 27
Threaded View
September 13th, 2014 05:48 PM #6
Your cooling system should be sufficient in controlling the heat levels if the other systems are working right. Other possible causes of overheat include too lean of air/fuel mixture, intake vacuum leak, too advanced ignition timing, improperly bled cooling system, pump cavitation due to loss of pressure in the cooling system, too high octane fuel and rust/scale build up in the water jackets
Posted through phlpost.gov.ph
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
