Results 1 to 10 of 10
    Jun 2006
    could this be a bearing issue? intact naamn yung fan belt. nakapagtataka.. kani kanina lang ako nag dridrive, bumaba ako sa cinnabon at kumain..
    pag sakay kong auto, wala ng hangin lumalabas. pero gumagana pa rin yung "click"
    i gave it like 5 minutes to see baa may hangin na lumabas.. the tube na steel, nag freeze. so ibig sabihin.. may lamig, pero alang hangin..
    napansin ko, nagiba yung tunog ng auto ko. nawala yung parang "humming sound.."
    tsk.. ubos pa naman ako kanina. bumili ako 2 liliput.. kaka bili ko lang ng tv sa auto, hindi ko pa nga naikakabit.
    diba yan blower?
    Air compressor... Dalhin mo na kay Mang Mario yan baka ma remedyohan pa.
    Jun 2005
    Aircon blower yan. Have it checked.
    nagyelo daw yata, so natural ma block ng frozen evaporator yung airflow kaya walamg buga
    blower, baka wala na carbon brush.
    the "click" means that the compressor clutch engages and the frosting of the tube means the compressor is working.
    the "no air" means that either your blower doesn't work or your evaporator is really dirty that the air coming out of the blower is blocked as soon as it passes the evaporator.
    from your post, most likely the blower connected to the evaporator is not working. check the fuse. if the fuse is ok, then could be a stuck up blower fan. or a loose wiring connection.
    in my case, nung na-stuck up ang bearing ng blower ko dahil antagal naka-garahe si oto, i just gave it a slight nudge, luckily umokei.
    Jun 2006
    sinilip ko yung blower. binaklas ko copartment. nagpalit ako carbon brushes, buti nalang mura lang.. 90 lang. just reshaped the carbon brush by sanding the sides to fit the housing of the carbon brush. ako na mismo gumawa. no choice. low budget eh. hehe.
    ok na sya.. this is the first time nakpa problema aircon nito in over 10 years. naubos talaga yung carbon brush. thanks for the inputs guys!! :D
    baka brush lang yon o yung fuse ng blower kaya ala ng binubuga na hangin,kaya nag yelo ang evaporator mo kasi ala ng dumadaan na hangin,na istak ang lamig sa evaporator mo kaya nag yelo
aircon ko walang buga?
