Results 1 to 10 of 31
November 11th, 2008 03:45 PM #1
My ride is a Nissan and my aircon setting is at 25 degress celcius. I find this setting to be the most comfortable. Not too cold and not too warm. Kaya lang whenever i take my car for PMS, pagkuha ko the aircon is down to 18 degrees celcius, which is just freezing for my taste. I'm just curious why the guys at the casa always put it in this setting. What's the benefit in setting the aircon at higher or lower temperature setting?
Kayo, ano po setting ng aircon nyo?
November 11th, 2008 04:01 PM #2
probably they also test the cooling capacity of your a/c by setting it at higher temp. but hindi nga maganda to leave it that way if your preferred thermostat is only at 25 degrees
mine is not digital, a simple slide switch which I normally set at 30-50% lang.
November 11th, 2008 04:03 PM #3
i dont know exactly the temperature readings pero i just set my thermostat at around 1-2pm.
November 11th, 2008 04:04 PM #4
pag pinasok kasi sa CASA.. dyan natutulog yung mga tech pag lunch break.. kaya todo aircon..
November 11th, 2008 04:06 PM #5
November 11th, 2008 05:44 PM #6
Sa Avanza, Fan at 2, Thermostat at first click from off.
Sa ZZ, Fan at 1 or 2, Thermostat at minimum.
November 11th, 2008 06:09 PM #7
November 11th, 2008 06:42 PM #9
Fan - set at maximum after start-up, then number 2
Thermostat - set at just above minimum
Factory aircon for the Adventure uses rotary dials, by the way.Last edited by Bogeyman; November 11th, 2008 at 06:46 PM.
The Yokohama BluEarths notoriously break down as you use them. I guess something in their...
Finding the Best Tire for You
