Results 11 to 20 of 20
4x4ph.com
- 695
January 8th, 2003 07:25 PM #11yep, ok lang kahit iwan mo na ang a/c switch on kahit nakapatay ang blower/fan... ganun ang mga sasakyan namin wala namang problema...
January 8th, 2003 07:30 PM #12
Diba gagana lang ang A/C when the blower is on? I have yet to own a car in which this is not the case. :mrgreen:
4x4ph.com
- 695
January 8th, 2003 07:33 PM #13pajerokid,
hehehehe! I'm not sure with the Paj pero may mga ibang kotse kasi may switch para lumamig, kahit nakatodo ang blower
January 8th, 2003 07:59 PM #14
pajerokid: Yes, the AC Compressor/Thermostat will turn on ONLY when the fan is on... But what difference does it make whether the blower fan is on or not? As soon as you switch your AC switch on (or move the thermostat lever), the compressor engages fully.
January 8th, 2003 11:38 PM #16
diretso ON din sa lahat ng sasakyan namin. yung ngang sa mga bagong aircon na digital na ang controls, pag naka AUTO, pag ON naka full agad ang blower, tapos pahina ng pahina hanggang ma reach ang desired temperature sa loob, then dun na sya sa pinakamahinang blower.
Signature
- Nov 2002
- 162
January 9th, 2003 12:49 PM #17thanks guys for the replies.
e is it true pag lagi mong pinipindot yung A/C button mas mabilis masira yung button, este yung aircon pala. :mrgreen:
January 9th, 2003 01:34 PM #18
siguro mas mabilis ang wear ng clutch ng compressor coz instead of nakaengage (or disengage) sya for a period of time kagat na ng kagat kung inooff at on mo...
- Jan 2003
- 5
- Nov 2002
- 29
January 9th, 2003 02:19 PM #20Perhaps it will be a good practice to turn on your ac at low rpms to give the compressor's oil sufficient time to circulate.
Turning the ac on at high rpms (eg while car is moving fast) is like reving the engine right after it started. IMHO lang...
Going back to the topic, ako rin diretcho na. But I make sure that RPM is less than 2K.
Kung bago na ang throttle body at servo motor, ang next suggestion i check sa YT search ay. 1....
LANCER Itlog (93-96) Owners - Please Post Here!
