Results 1 to 10 of 20
- Nov 2002
- 162
January 7th, 2003 04:00 PM #1how do you turn on your car aircon? fan ba muna then A/C?
Nalilito na kasi ako. Sabi nung iba wag daw pindutin yung A/C button kasi mas mabilis daw masira. Sabi naman ng iba dapat fan daw muna parang yung room airconditioner.
January 7th, 2003 05:09 PM #2
actually mystery din sa kin yan eh.
pero to be safe, i follow what everyone does... fan muna bago a/c. i also close a/c first before the fan before turning it off.
ang reason daw is para maalis muna yung mga stagnant na dust na nagaaccumulate sa filter (o blower) bago pumasok ang A/C which can lead to bara.
i just don't know if its true or not, pero its better be safe than sorry.
FrankDrebin Guest
January 8th, 2003 11:09 AM #4
Ako diretso na.
- 290
January 8th, 2003 11:36 AM #5this is what i do/will do:
start engine
window down
drive immediately and slowly
after a few seconds turn blower on
then a/c on
window up.
applicable sa akin dahil manggagaling ako sa subdivision so hindi mausok kahit bukas bintana in a few seconds.
kapag garahe na, a/c off then blower off ang logical as suggested by happy_gilmore.
- 51
January 8th, 2003 05:44 PM #6same here... diretso na.... 8 years na car aircon ko, no repair done yet.. :arrow:
January 8th, 2003 05:59 PM #8Originally Posted by OTEP
hahaha..!!
basta hwag lang itotodo sa maximum.
un ang sumira sa air-con ko dati eh.
January 8th, 2003 06:33 PM #9
kiper: yung maximum switch sa fan lang yun di sa AC... yung thermostat ang nagcocontrol sa AC...
ako derecho na once umaandar na ng maayos yung oto (around a few secs/blocks)...
di naman kailangan i-gradual ang on ng AC... it doesn't increase or decrease wear on the AC compressor since walang kinalaman yung fans sa thermostat.... basta nagon yung thermostat mo mageengage yung clutch sa compressor... either on or off lang naman yung clutch na yun at walang gradual operation...
The blower is purely an electrical connection... kaya nga kahit naka off ang engine gagana ang blower...
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
