Results 31 to 40 of 40
September 12th, 2012 01:10 PM #31
yes, since napalinis mo na radiator mo, lowslowbenz reply may be the problem.
- Aug 2005
- 553
September 12th, 2012 02:56 PM #32
- May 2008
- 124
September 21st, 2012 09:42 AM #33had the same problem. found out that my timing was too advanced which caused the engine to run hot. the temp guage was not accurately indicating the overheat problem.
- Aug 2005
- 553
September 22nd, 2012 06:56 PM #34Even if its advanced, your cooling system should be able to handle it. Though it would mean your fans would turn on more often.
If you're overheating there's something definitely worth looking deeper into.
September 30th, 2012 11:02 PM #35
- Aug 2005
- 553
October 1st, 2012 02:53 PM #36
- Aug 2005
- 553
October 10th, 2012 06:02 PM #38
TS ... so what was the cause of your "kumukulo na tubig"? Can you update your thread?
November 4th, 2012 09:37 PM #39
had experienced this problem lately... buti nakita ko na malapit na sa overheat yung temp ko... Any advice on where to have the cooling checked up? Can those Gas Station services be able to fix this and check up on this or do I need to go somewhere else to have this problem fixed?
any recommendations in Manila area?
November 5th, 2012 07:25 AM #40
Sir kindly check your water coolant and radiator for possible contamination of oil and water, check radiator( barado)thermostat, aux fan, muffler for smoke, cylnder head gasket.. Bumagal po ba ang takbo?
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
