Results 11 to 20 of 24
September 30th, 2006 09:08 AM #11
sana pala nag vent lang un high pressure releif valve ng comp so wala gaano damage
- Jan 2006
- 44
September 30th, 2006 10:07 AM #12low - 40 psi
high - 350 psi
350 psi for the high side is way much over the required pressure of 150 - 160 Masyadong mataas yata yan, could be your condenser fan failed and your pressure switch was probably disabled or bypassed kaya di nag cut off ang compressor mo.
- Jan 2006
- 44
September 30th, 2006 10:20 AM #13low - 40 psi
high - 350 psi
I am having the same problem right now. My van stopped cooling and I have it a complete checkup. Flushed my system, replaced the expansion valves 2 kasi front and rear aircons, replaced drier/filter. Then recharged the system and ok na, malamig na. Test drive it, nawala lamig. Compressor stopped and when we checked the high side pressure wow, 300+. Reason,, condenser fan is not working. I am having it replaced today. Hopefully, everything will be allright again.:icecream:
September 30th, 2006 09:32 PM #15
have to check it kasi ung uncle ko na pumunta sa shop
hindi ko pa alam results kasi kadadating ko lang sa bahay.
grabe kala ko sumabog na engine ko, parang sa F1 me usok usok pa hehehe
- May 2006
- 78
September 30th, 2006 10:46 PM #16Bugbugin mo yung tesda Technician na yan, sinadya nya yan. the normal pressure is 45-60 sa suction or you can go 40 psi but not lower than this. the discharge should have 250-265 psi. Kung napalitan lahat ng bagong filter and expansion valve and considering na bago yan di dapat yan umabot ng 350, sasabog talaga yan. Kung meron kang pinakabit na fusible plug, yon lang ang bibigay pero malamang wala yan non kaya ang bumigay mga fittings. Sayang ang freon. Mostly dapat mataas ang ambient temp mo sa tuwing magkakarga ng freon kasi pag sa umaga ka magcharge ng freon mababa ang presure na makukuha mo kaya pagdating ng tanghali tumataas yan.Mas advisable kung sa tanghali or tirik ang araw magpa karga.
Di nya alam ang ginagaw nya, tesda technician pa naman sya.
September 30th, 2006 10:55 PM #17
uu nga eh pero nacheck ko na yung sasakyan although hindi ko
start pa, pero nakita ko na yung hose, sabog as in sabog ung
rubber nya parang bulaklak eh, tingin ko pinalitan nila yun for free
since mali yung process nila, medyo mataas lang yung pressure na
nilagay nila.
Tsikot Member Rank 3
- Sep 2003
- 786
October 1st, 2006 02:51 AM #19ganyan din nagyari sa car ko dati, kala ko din sumabog na angine ko. imo, na sobrahan nga pressure yan.
VinFast VF 3
