Results 1 to 14 of 14
    Sep 2006
    ano kya problema ng aircon ko bkit twing i-on ko aircon ko bumababa yung rpm ko
    hindi ba dating ganyan? usually bababa talaga ng konti ang rpm because of the added load kapag nag-ON ang aircon. pero konti lang dapat.
    kung malaki ang binaba ng rpm mo, baka malapit ng mag stuck up yung compressor mo and the engine is having a hard time turning the compressor kaya malaki ang binaba sa rpm.
    May 2005
    Kung efi ang unit mo e sensor or ecu ang may problema dyan. Kung lancer singkit yan e servo or trottle body may problema dyan.
    Sep 2006
    one of the solutions can be, if that is carburated one, attach a "step-up" inaangat niya ung idling ng engine once na i-turn on mo yung aircon...
    Sep 2006
    toyota xe unit ko, carburated. d kya yung equator ko yung problm. tsaka what meant pla dun s bumama yung rpm is yung tachometer reading ko. d b dpat pumalo pataas yung tach ko kya lng yung akin bmbgsak kpg ngaircon ako. can i mechanic solve this or i should bring it to a aircon specialist?
    go to a trusted mechanic first to let him rule out compressor problem. kung compressor daw talaga ang may problema, tsaka ka pumunta sa aircon specialist.
    Quote Originally Posted by lightninmcqueen View Post
    bro, ang problem po ng aircon mo is the fan . hindi po sya humihinto sa kakaikot, kaya malamig ang radiator mo. based po kasi sa experience ko, ganyan ang problem before ng car ko. kumusta naman po ang aircon? malamig naman ba ang labas o mainit na?
    Jul 2006
    "Bumagsak" is very subjective. When you just mean na yung RPM "dipped" as in kaunting baba lang, normal yan. The compressor uses 1 or 2 HP from your engine kaya yung rpm bababa.
help! rpm goes down when aircon is turned on
