Results 1 to 10 of 35
May 5th, 2010 03:56 PM #1
greetings. after having high speed overheat, i decided to flush my rad then refilled it wit coolant mix but i noticed small bubbles until it overflow (like soap bubbles. could it be a HG turned bad, or something else?
if it is really a HG problem, any shop yu could recommend and how much do yu think i need to prepare? my car is an old accord 95 exi a/t.... many thanks in advance, regards to all...
btw, for reference, mine is overflowing with tiny/small bubblesjust like in this video ..http://www.youtube.com/user/mickbmx#p/u/7/Lk9-JhHzAKQ
May 5th, 2010 07:23 PM #2
Sir nagoverheat na po ba ito? baka may deperensya na yong cyl head gasket.
Kung malapit kayo sa location namin, Try niyo po pumunta sa shop namin bukas.
[size=14pt]JOPREMAR ENTERPRISES[/size]
Fermin Aircon, Electrical and Radiator Shop
Address: 1291-A Quirino Ave, San Dionisio, Paranaque City
Tel: (02) 829-3771 / 775-2293 Text: 0915-5413610
email to: jovi1645*hotmail.com
http://sulit.com.ph/1522292
- Jan 2010
- 38
May 12th, 2010 06:48 PM #3peztie sir ano po nangyari na sa car niu? ganyan din kasi yung car ko pero di naman nagooverheat. it runs normally naman.
- May 2010
- 2
May 16th, 2010 09:50 PM #4Hi Sir,
Normally when the HG will go bad, you have to replace it with an OEM instead of bringing it to the machine shop for re surfacing. I have a mitsu lancer & the OEM HG costs 1, 700 PHP at shaw merchandising. Yours is honda so i suggest you check with supplier.ph the price of an original HG.
BTW, check you oil cap if you will notice a mix of oil & coolant. If YES, the HG or the CH might be in bad shape already. Also, white smoke in the tail pipe with water or coolant indication shows that the coolant is already flowing in the combustion chamber.
Try speedyfix. Sir Migs is the best judge for that cases. He can give you a rough estimate for your case.
May 17th, 2010 03:27 PM #5
May 17th, 2010 04:46 PM #6
Gumagana ba iyong auxillary fan mo. Subukan mo buksan sa umaga iyong hindi pa mainit makina mo ang radiator cap . Pa start mo sa kasama mo makina tignan mo kung bumubulwak o lumalabas ang tubig sa bibig ng radiator kung lumalabas head gasket iyan . Tignan mo rin iyong thermostat.
May 18th, 2010 02:24 PM #8
* speed_unlimited: sir ok yung 2 fans, gumagana din yung thermo switch. wit regard sa pag start kung me tubig bubulwak, negative din sir.....
update ko na din mga sirs, nawala na yung mga bubbles probabaly because ni re-torque ko yung head as advised in other threads. but the problem is still there, overheat pa din pag long driving, pag traffic wala problem...any ideas mga gurus....TIA
May 18th, 2010 04:15 PM #10
Kadalasan iyong madalas mangyari pag traffic nag ooverheat dahil nakahinto at hindi nakakasagap ng hangin baliktad iyong sa iyo . Ang mga cause ng overheat check mo na lang Radiator maaring barado , Sirang radiator cap, radiator hose may leak . Nagbabawas ba ng tubig check mo kung may leak sa mga clamp ng hose. Sa tingin ko sa video barado iyong radiator mo pa check mo muna sa gumagawa ng radiator. Ganoon muna gawin mo at sabihin mo sa amin resulta.
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
