Originally Posted by
kidlatfernandez
Hi Sir,
BTW, check you oil cap if you will notice a mix of oil & coolant. If YES, the HG or the CH might be in bad shape already. Also, white smoke in the tail pipe with water or coolant indication shows that the coolant is already flowing in the combustion chamber.
Try speedyfix. Sir Migs is the best judge for that cases. He can give you a rough estimate for your case.
