Results 1 to 1 of 1
- Jan 2011
- 262
July 11th, 2011 11:28 AM #1Hi sirs, I just noticed the other day that the water inside my radiator has some slight rainbowish color, it looks more like a rainbow swirl to me. Could this be a sign of a busted cylindrer head gasket? Should I replace it ASAP?
I'm not overheating naman. Sometimes my temperature goes up above half but (a bit higher than the midway point but not up to 3/4) goes back to half after a few seconds.
I popped up the hood a day after I noticed the rainbow swirls and took the radiator cap off, I used my flashlight to take a closer look inside my radiator. The presence of the rainbow swirls was not present but I saw some tiny specks. It doesn't looks like rust to me.
How can I know if this is really oil in my radiator? I need you help badly before I make some drastic moves. Thanks tsikot! BTW my car is a 95 Civic.
high idle RPM at engine start
