Results 1 to 10 of 11
- Oct 2008
- 469
October 21st, 2008 06:41 PM #1Ask ko lang po san po magandang shop here at QC bumili ng surplus compressors for Sentra ECCS. Magkano po kaya price ngaun?? Calsonic san po kaya merun na surplus
October 21st, 2008 11:22 PM #2
Calsonics are expensive, and surplus items may not last long, as the mechanical clutches on Calsonics are rather fragile. Better to convert it to a more robust Denso or Sanden unless you're buying a brand new compressor.
October 21st, 2008 11:38 PM #3
plus one on niky
never try to buy surplus maybe in the short period of time okay ang surplus but in the long run palagi ka na lang bibili ng surplus. better convert it to denso or sanden na brand new. anyway i think your from QC pede ka mag drop by sa e rod may mga shop dun na mura magbenta ng a/c parts. may sanden 501 bought from e rod around 4K lang
- Oct 2008
- 469
October 22nd, 2008 04:00 PM #4Ahh, ganun po, ehh dba po Calsonic po ang OEM ng sentra?? San po banda sa E.rod mga nagbebenta ng compressors?? Tnx for all your inputs.
- Oct 2008
- 469
October 24th, 2008 03:18 AM #5May binebenta po pala sakin yung friend ng utol ko na stock compressor. Maayos pa daw po talaga kaso, nasira lang daw yung pulley. My nabibili ba na pulley lang for compressor??
October 24th, 2008 10:19 AM #6
Yung pulley yung mahirap.
See, the Calsonic uses a mechanical clutch on the pulley mechanism. This clutch is what helps attach or disconnect the compressor from the pulley. But a surplus clutch will have issues... poor lubrication, stuck-up mechanisms... it's easy for a surplus clutch to break or becomes stucl.
That's why a surplus Denso is a good idea... they use a rubber clutch... and while these might conceivably degrade over time, they won't get catastrophically stuck.
You can buy clutches separate from the compressors, but having once bought three clutches in a row (all of which failed within a month) for my surplus Calsonic on my SR20, I'm kind of wary of doing this.
October 24th, 2008 06:49 PM #7
dont buy a surplus compressor for your nissan and specially wag mong convert ang compressor mo s ibang brand if ayaw mong magsisi sa huli.
try to find a brabd new compressor.
October 30th, 2008 10:51 PM #8
that's right! don't convert. hassle yan cause di sya same spec ng OEM compressor mo. try to call up MRV 721 0156. i bought my new calsonic compressor at a very cheap price.
- Oct 2008
- 469
October 30th, 2008 11:47 PM #9sir non-vtec, pwede malaman price??hehe. My neighborhood bought calsonic surplus for 4.5k at banawe! 6 months na nya gamit, but super lamig at ok na ok pa rin. Galing daw po japan. My stocks pa daw ehh. Ok po kaya yun?
- Oct 2008
- 469
October 30th, 2008 11:47 PM #10sir, senya na, pa extend ng message. My nabibili pa na pulley lang??
Monk-owned R53
