Results 1 to 10 of 12
- Apr 2009
- 272
May 24th, 2016 05:27 AM #1Tumataas kasi ang temp sa gauge everytime mainit ang morning and especially traffic. Pero pag gabi ok naman kahit traffic. Wala naman visible leak sa cooling system. Bago din ang reservoir thermostat and radiator cap. Problem is lagi nauubusan yung tubig sa reservoir d ko lang sure if this is normal. May pressure test kaya sa servitek?
May 24th, 2016 06:15 AM #2
May konting tagas yan bro.iopen m ang hood pag mainit ang makina at tignan mo kung may tumutulo pati sa ilalim.pag mainit makina mataas ang pressure kya dun sumisirit yung coolant
Sent from my E6853 using Tsikot Forums mobile app
- Apr 2009
- 272
May 24th, 2016 12:01 PM #4It didnt reach the H mark but mga 3/4 na lang. Do you consider it as overheat na? Im thinking it could be the water pump coz its the only part that i didnt change.
May 24th, 2016 12:26 PM #5
Meron leak yan. We use uv reactive dyes to trace leaks in our water chiller systems.
- Jul 2013
- 2,450
May 24th, 2016 12:45 PM #6I suspect a radiator that needs to be cleaned/overhauled.
Walang leak pero hindi na masyado nagdidissipate ng init ang radiator mo dahil madumi na sa loob. At least that is my suspicion.
- Mar 2010
- 2,273
May 24th, 2016 12:46 PM #7
May 24th, 2016 04:33 PM #9
Same thought. We had a high temp issue with our car over the past few months with similar symptoms. After checking everything else, turned out the radiator simply was not flowing enough coolant.
You can tell that this is the case by checking (carefully) if both hoses are warm. If one is very hot while the other is cool (when the engine is running hot), that's a clogged radiator.
- Apr 2009
- 272
Taguig shouldn't be blamed over cancelled Makati Subway System -mayor | GMA News Taguig shouldn't...
Makati Subway. Completion date: 2025
