Results 1 to 20 of 22
    Jun 2009
    Hi, has anyone experienced a problem sa aircon fan? Kapag #1 halo walang buga, #2-#4 malakas naman... wala din problem sa lamig...
    anu kaya issue nito? gusto ko lng may idea ako para kapag dinala ko sa aircon shop di ako maloko...
    Honda City 2011 pla car ko.
    Jun 2005
    Either madumi yung fan mo or sira/pasira na resistor block ng fan mo
    Jun 2009
    Quote Originally Posted by sirkosero View Post
    thanks sa comment sir. may rough estimate ka ng cost nito? for cleaning or for potential replacement ng resistor block?
    Quote Originally Posted by frost2 View Post
    cleaning, you can do it on your own DIY style.
    resistor block, imho, is less than 500 pesos, but you need someone to install it for you.
    in any case, try cleaning it first.
    Jun 2009
    Quote Originally Posted by 1D4LV View Post
    thanks sir very helpful... dalhin ko tommorow sa aircon shop near me.
    Jun 2009
    Sir, napa check ko po, sabi nung una resistor block lng daw, tapos tumawag bigla sabi buong assembly nung blower daw need palitan..
    any idea po kung may 1: remedyo pa sa blower? 2; may mga surplus na unit po kaya at how much.
    note: 12K daw yung brand new na blower.. di ko po kaya...
    2011 honda city.
    Jun 2005
    Hanap ka ibang shop.
    Pineperahan ka lang nyan.
    Oct 2009
    ang bili ko ng surplus 500 ikaw na magkakabit motor lang un saka mo ilalagay sa dating housing niya.may brandnew din ang kuha ko ay 2.5k motor lang din yan ililipat lang ung pinaka fan niya.
    Jun 2008
    Uhmm.. maliwanag na gusto ka kwartahan ng tao na yan.
    Sent from my Lenovo A7000-a using Tsikot Forums mobile app
    Jun 2009
    thanks sa mgaadvice... got a "bnew" daw blower all together..sa ibang shop. 2700, kasama kabit...
    so, the problem was the blower and not the speed control?
    Feb 2005
    paanong naging blower ang sira nito? kung sa ibang speed eh gumagana?
    Jun 2009
    yung blower daw may sira nag stuck-up. nung inayos nila yung resistor block, na sira ulit after ni try nila kasi yung blower daw may stuck up..
    perhaps the motor bushings were already ground useless.
    when run at low speed, the armature barely turned, and no air was pushed out.
    when run at higher setting, the larger oomph caused the armature to turn faster, pushing more air, giving the semblance that it was functioning ok.
    that being the case, motor replacement is the solution.
    Jan 2014
    I also have a problem with my aircon fan, ngayon maingay na sya na dinig mo kahit nka bukas ung radyo sa oto. Ano kya need gawin dto mga paps? Thanks.
    Quote Originally Posted by akosidab View Post
    sigurado kayong sa aircon fan sa loob ng dashboard ang ingay, ha...? hindi sa aux fan sa harap ng makina.. or sa compressor... or maluwag lang ang fan belt...?
    baka may sumasayad.
    kung minsan, ito ay dahil may bumagsak sa loob at sumasayad sa rotating parts.
    minsan naman, yung moving part mismo ang sumasayad sa "cage" niya. kailangan ng alignment or replacement, siguro.
    pa-tingin nyo po sa shop. hindi naman mahal magpa-tanggal ng foreign object, or re-alignment...
    medyo mas mataas kung replacement...
    good luck.
    Jan 2014
    baka may sumasayad.
    good luck.
    Sorry for the confusion, ung maingay sir eh ndi sa loob ng dashboard. Ung aircon fan na malapit sa radiator. Un ung maingay.
    see if the fan blades are rubbing against something. then see if it can be remedied.
    if none, or if you can not, then i suppose it is time to replace the motor or (ugh!) the frame/assembly. most motors can be removed from the frame and replaced.
    aux fan servicing is a straightforward thing. the most difficult part is usually the money.
    if your replacement part is hideously expensive (8K for some), you might try the generic ones selling for less than 900 bucks for the entire assembly. see if it will fit yours, with a little tweaking.
    good luck.
    Jan 2014
    good luck.
    Thanks dr d. Very much appreciated. Tom will try to check if i can remove thr fan and clean it. If the rubbing noise will still be there then will be needing to drop into an auto aircon shop.
Aircon Fan Problem
