Results 21 to 29 of 29
April 2nd, 2008 05:38 PM #21
April 2nd, 2008 05:44 PM #22
Check first if the power cord for the second fan is connected. The cord is just right there usually near the radiator crossmember.
I believe the other fan will only turn on when the engine temperature reaches a certain degree well above normal, close to overheating but just early enough to prevent it. At least that's how I understand them.
- Nov 2007
- 132
April 2nd, 2008 06:06 PM #23The power cord for the 2nd fan is okay. Because when the technician installed the new radiator, he tested it to get the correct wiring connections and correct direction of rotation. So during the installation, I saw the 2 fans running at the same time.
Perhaps ur right about the 2nd fan starting at a predetermined higher temperature. Only now, I have no idea of testing if indeed it does work.. assuming that under normal driving conditions, I could never reach that kind of temperature.
- Jan 2008
- 380
April 3rd, 2008 08:42 AM #24The Main Cooling Fan is connected to the Thermostatic Switch which is usually connected sa radiator. This switch will close (switch on)the circuit if the coolant temp reaches a certain degree and will be off again pag medyo malamig na uli yung coolant.
Usually past half the temp gauge pa bago kick on ang Thermostatic Switch. Sa isa kong kotse just before the Red Line yung isa naman mas mababa ang setting.
Dapat meron thermostatic switch for automatic Main fan control, but you can manually switch it on and off lagyan mo lang ng bagong circuit at manual switch.
Di ko pa kabisado yung control ng low at high speed setting ng Main Fan ko pero palagay ko gamit ito resistor somewhere in the circuit. Mahirap pakialaman computerized kasi.
- Oct 2007
- 120
April 3rd, 2008 06:13 PM #25The thermostat is an integral part of the any cooling system. Removing it will cause the car to run longer at sub normal operating temp. Running at sub normal temp is the worse torture you can do to your engine. That's why idling to warm-up is not good. It will take longer to reach normal operating temp. Upon starting just allow enough time for the oil to circulate & drive off slow. Notice that at about 1 km you have reached normal operating temp. That is if you still have your thermostat on. Removing the thermostat is a convenient shotgun solution to an overheating problem. If your car overheats with a good thermostat on just means there are other problems in your cooling system. "Hindi kailangan ang thermostat dito sa Pilipinas" is a old, old urban legend.
- Jan 2008
- 152
May 1st, 2008 01:23 PM #26need help guys....
it's been around over a month and i still can't find a replacement for my thermostat. my car is a 1.3 b13 sentra.
what's available is slightly longer at the top from what i have. it might not fit properly.
any suggestions?
thanks
May 3rd, 2008 11:50 PM #27
Have you tried at Banawe? There are some Nissan specific stores that might have it. GA-block thermostats should be common parts, but from what I remember, the 1.3 - 1.4 blocks are a bit different from the 1.6, so that's where you might be having a problem.
- Jan 2008
- 152
May 5th, 2008 01:24 PM #28
- Nov 2007
- 132
May 8th, 2008 05:43 PM #29Hi guys, it's been a month since I posted in this thread. Just want to update about my problem with the fan. turned out that the root cause is loose wiring that's why the AUX fan won't start. I had the wiring re-done and ensured that the splicing won't come off.
And it's also now that i have studied the fan operation. From cold start, the fan won't start with the engine - of course, because the engine needs to warm-up. Then when it's hot enough, the aux fan begins to spin. Then when the water cools, the fan stops. Therefore it is a start-stop-start-stop affair.
However, it's a different story when I switch on the aircon. Both fans will start at the same time. This is understandable since the A/C compressor is an additional load to the engine.
I'm happy it was only a small problem. No need for expensive parts replacement. Just gave a violet bill to the technician and that's it
Xiaomi E-Car
