check engine fan if it does work normally, mabilis ang ikot. palinis radiator, check radiator cap if it still seals. if all else fails baka sa head gasket na yan. pag may leak between your combustion chamber and water gallery the compression pushes water out of the radiator hence the bubbles that you see when your remove the radiator cap. water should just circulate/flow when your view it in the filler hole. pag pinaalis mo thermoswitch palaging naka on engine fan mo which would reduce your fan life to half and will increase your fuel cnsumption snce your engine would take longer to reach its operating temp.
