Results 11 to 20 of 27
April 13th, 2009 01:58 PM #11
Happened to me before, pag traffic or idle, medyo mataas yung temp gauge, tapos mainit yung buga ng aircon. Turned out na mahina na yung ikot nung isang rad fan. Akala ko puwede sa carbon brush, pero sealed type pala yung fan ng Sentra Series 3. Ended up buying a surplus fan.
Pa-check mo rin yung radiator mo kung barado. Mura lang naman pa-overhaul, less than P500 (top overhaul ng radiator). Kung pati yung ilalim babaklasin, alam ko P900~ ang singil sa mga rad shops.
April 14th, 2009 08:41 AM #12
nothing worng with your thermostat as u have expalined from the test done. function lang ng thermostat is to immediately warm up the engine such that yung tubig lang sa loob ng engine block ang laman. once it get's to operating temp, the thermostat will open so water can start to circulate as you drive and it will keep open until engine cools down again (pagpatay na).
since hindi naman nababawasan ang tubig & your fans are operating, you may want to try experimenting on a new fan na masmaraming dahon para masmalakas ang buga ng hangin.
DIY to death!
- Jan 2003
- 451
April 14th, 2009 09:49 AM #13With the symptoms you describe, I'd agree with the others. Baka mabagal na umikot fan mo. Pa-tignan mo kung pwede pa i-repair, pero mura lang naman yan, so a new one isn't a bad idea either.
April 14th, 2009 11:51 AM #14
ok.. i'll have the radiator fan replaced over the weekend..hopefully yun na nga yung solution...
pero ano kaya yung reason kung bakit nagooverflow yung water sa reservoir bottle at the time na tumataas yung temp, tapos halos wala nang water sa radiator? as in na top up yung reservoir bottle with the water+coolant mixture. yung radiator fan na rin ba culprit nun, or something else?
DIY to death!
- Jan 2003
- 451
April 14th, 2009 12:12 PM #16
That is actually quite normal when you dont use a proper coolant and
the car has aged a few years. It is called wear and tear. The performance
of the cooling system degrades thru the years.
When you checked on the water leak, were you using a proper coolant?
It is very difficult to check for leaks using water in your coolant,
but you can use your FLIR weapon sights you have on your rifle if you
have one or can borrow. It works.
What you should do is pay attention on the type of water you use to
top off your radiator. Avoid deep well water if you live in a subdivision.
Use a proper coolant.
Please read the thermostat debate thread.Last edited by mark_t; April 14th, 2009 at 12:20 PM.
April 14th, 2009 12:28 PM #17
April 16th, 2009 01:42 AM #18
i observed the radiator fan last night, car wasn't used the whole day, and here's what happened:
- turned on the engine, then turned on the air condition system,and waited until the gauge reaches the normal operating temp.
- approx 15 minutes after the engine reached its normal operating temp, the radiator fan turned on for a duration of 15 secs then shuts off.
-radiator fan turned on again after an interval of 2-3 minutes, and again spins for exactly 15 seconds.
-timed the next interval, and after about 4 minutes, the radiator fan started spinning again....
so mga sir, is it safe to say that my radiator fan is functioning normally, or should i still go and have it replaced? based nman sa speed ng ikot nung fan, same speed naman sila nung fan para sa condenser.
April 16th, 2009 02:45 AM #19
wicked,
to put an insight into your modern car's cooling system, they are normally designed to operate at optimum efficiency by conserving heat and at the same time prevent your engine from overheating. your car is designed to operate between 190-240 degrees fahrenheit to reduce exhaust emissions of unburnt fuel and prevent the formation of oxides of nitrogen in case of an overheat. your car's radiator contains less coolant compared to the cars of the sixties where the capacity is less demonstrated by a small single row radiator for three reasons: 1.- warmup time is reduced, 2. -the vehicle is lighter with less coolannt, 3.- the engine is not overcooled.
the system is cooled two ways; a. by the fan thermoswitch controlled fan, b. the ambient ram air when the vehicle is in motion. your description of the symptoms is that it happens when there is no ram air. things that can contribute to this vehicle stopped/engine running overheat are:
the radiator airlow is blocked by a bugscreen or nosebra, the radiator has been painted over insulating the cooling fins, the radiator fan is unable to pull or push air through the radiator or leaves or debris are present in front of the radiator.
in the case of the coolant not returning normally rom the recovery(reservoir, surge tank however you may call it), check for partially clogged hose between the radiator filler neck and the recovery bottle and for vacuum leak on the hose. you've mentioned that the radiator cap had been replaced. the normal rating for honda caps is 0.9 kg/sq.cm.(roughly 13 p.s.i.) check for pressure valve gasket or seal and the vacuum valve seal on the same cap(compound cap). for lack of complete information of your car, check to see if the cooling system needs to be bled as today's cars have lower hoodlines and the radiators are usually lower than the engine trapping air pockets in the cylinder heads.
jick
Tsikot Member Rank 4
- 2,719
April 16th, 2009 03:47 AM #20i had a very similar experience with my former esi ... after radiator overhaul, changed plastic top into copper, and radiator cap with generic one ... the car ran for a few weeks without trouble and then the problem is back ... losing water
i supected the radiator cap, but since it is fairly new, i figured maybe the top rubber seal isn't quite up to specs (it looks thin) so i tried adding another rubber seal from a tire interior rubber (cut with scissors) and it worked!
Yaris Cross: ₱ 200,000 for S HEV Zenix: ₱ 150,000 for 2.0 Q HEV CVT
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
