Results 1 to 10 of 29
- May 2007
- 133
August 15th, 2007 02:05 PM #1mga sir gud pm!
ask ko lang po kung ano ba ang proper maintenance ng radiator? every ilang months po ba cya dapat nililinis? ok po ba gumamit ng coolant compared sa ordinary na water? please advise, thanks
August 15th, 2007 02:18 PM #2
Ah, dapat talaga coolant ang ginagamit. Using ordinary water will corrode your radiator.
August 15th, 2007 02:38 PM #3
as much as possible, drain your radiator at least once a year, but if you can afford it, at least, every six months. yun nga lang medyo magastos sa coolant, pero its all worth it.
pwedeng i-DIY yan. just look for the drain faucet at the bottom of your radiator, drain everything (make sure that the engine is off), and mix a 1:1 coolant-water mixture, close the drain faucet, put the mixtureinside the radiator, and start the engine. check mo maigi kung walang tagas and yung response nung temperature ng oto.
it is recommended that you use a coolant mixed on the ratio stated above. why? aside from protecting your radiator from corrosion, it boils at a higher temperature, making your engine more protected from the heat.
recommended brands? maski ako.. but i personally use yung Shell brand.
Tsikot Member Rank 4
- 1,842
August 15th, 2007 03:16 PM #4Double Post
- 1,842
August 15th, 2007 03:16 PM #5we have a 5 and 2 year old car prior to that some 3 and 4year old car.
I never used Coolants just some distilled water or sometimes even just MAYNILAD water. I never had problems with all those car concerning radiator. I just change them almost twice or even up to 4 times a year. (We had a car 4 years hinid napalitan ang tubig, nagputik na yata sa kalawang heheheresulting to overheat)
I believe the trick is in the frequent flushing. Not on some additives or even at the coolant
I think its true that coolant has a higher boiling point but i think the corrosion or rust is still there. The color of the coolant just hides it.
And whats with these Hardware malls selling Preston Anti Freeze
e anyway?
- May 2007
- 133
August 15th, 2007 04:56 PM #7
gusto ko lang po itanong... every week ko po pinpalitan ng water yung reserve tank ng radiator... meron po kasing color brown or putik na residue dun. never naman ako naka encounter ng overheat ano po kaya yun? btw, i only used distilled water and no coolant. tnx
August 16th, 2007 11:49 AM #8
August 16th, 2007 12:23 PM #9
August 16th, 2007 01:03 PM #10
Nakow, kulay putik. That means naghahalo na yung oil at tubig. Pa-check mo na yung cylinder headgasket mo, sure ako may tama na yan.
Hybrid is the way to go. So you don't rely heavily on the batteries.
Hybrids and EV
