View Poll Results: Regular Aircon Cleaning: To be or not to be? Post a Poll
- Voters
- 29. You may not vote on this poll
Results 31 to 35 of 35
September 15th, 2007 07:56 AM #31
Kapapagawa ko lang ng A/c ko sabi nung pinagpagawan ko minsan daw dun pa nasisira yan sa pagpapalinis kaya wait na lang pag medyo bumaba na performance di naman siya ganun ka critical, dapat lang malinis lagi yung cabin para matagal siya dumumi
- Sep 2007
- 10
September 15th, 2007 10:33 AM #32better have the air con clean annually yun sira ang compressor or cooling coil can be pre determined pag check the pressure of your freon yun cooling coil numinipis sa katagalan ng gamit there are instance that ngkataon lang malalaman butas yun coil pag nalinisan but parating na yun dun matter of time lang and if you maintain one particular product kahit di air con mas tumatagal siya even out body needs maitainance
September 18th, 2007 12:57 AM #33Sir,
In 2-3 years na annual cleaning niyo mukhang makakabili na kayo ng brandnew na evaporator.
- Sep 2007
- 215
October 11th, 2007 10:40 PM #35FYI
Aircon of car doesn't need a yearly cleaning ... but if your rich enough if couldn't be that bad
Aircon cleaning usually cost about 1200 depending on what car and depending on which parts are needed to be replace
for instance basic car model ... usually cost 400- 450 dryer, 700 - 1200 for the expansion valve ( usually honda cars has higher expansion valve since it is lighter type )
for freon this ranges from 600 - 650 for single aircon meaning the aircon is in the front
dual aircon car like fx, revo which has aircon both front and rear costs around 1200 - 1300
for cleaning dual cars usually more expensive about 2800 php this is for general cleaning ... * gen cleaning is removing all parts or aircon, flushing, cleaning and replacing ofr dryer, o ring the works .... usually costs about 5000+
for those you want to know how to know when your compressor is broken ... usually check ninyo kung sound ng compressor .. yung iba bearing lang ang sira ... which you can hear it
meron naman walng lamig ang aircon pero puno yung freon ... this means compressor is nagloloko na
pag ang car minsan may lamig and minsan walang lamig ... walang pressure yung aircon mo (karamihan crv ang may sakit na ganito) ... palit compressor na ito ... mga 18k yata pero mayaman ka naman eh crv yung car mo diba ;)
for any more questions
BANAWE AUTO SUPPLY
7120115
regy
Any reviews for the Triton GLX 4WD 6MT? Siya ata pinakasulit na middle 4WD variant. Price range...
2022 Mitsubishi Strada/Triton (6th Generation)
