Sir saang shop ka nag pa calibrate at machine shop? Tpos ung previous post nyo regarding sa overhauling ng radiator saang shop nyo po pinagawa? Hinang po ba radiator nyo? Pansin q kasi ung sa akin naka clip lng po ung pinaka top cover.
Thanks po..
Quote Originally Posted by wham_10mbps View Post
thnx sa response treborhon. Wala naman leak ang overflow container. Walang noticeable leaks anywhere when left parked overnight.
At any rate, masakit sa bulsa pero oks na ang ride ko. Salamat sa lahat ng nag respond sa thread.
Eto po summary for reference purposes:
Problem: Radiator overflow container not returning water to radiator. Temp hitting high. Loosing water on Rad. Several long drive incidents hit the 3/4 mark which alarmed me to have it checked by a mechanic.
Cause/Diagnosis: Pressure build-up on cooling system. Rad is filled up with air/gases coming from engine and fills up overflow container. Rad hoses are hardened after few minutes of driving. Bubbles on the rad opening.
Culprit: Cylinder Head, Cylinder Head Gasket
Resolution/Cost:
1. Top overhaul labor / 3,000
2. Replace Cylinder Head Gasket / 1,800
3. Machine shop works e.g. hyro/crack test, cyl head resurface, valve guide reface etc. / 3500
4. ReplaceValve seals and related parts / 2,500
5. Calibration and replace faulty injector tips / 4,500
6. Change engine oil, ATF, 30% coolant / 2,500
