Results 1 to 20 of 22
    May 2004
    mga sir,
    san kaya prob pag may whistling sound pag naka on yung aircon and mataas rev? kse dati wala naman.. nung pinahigpitan ko yung belt ng compressor ( lumalangitngit kse dati).. tsaka lang sya lumabas... dati langitngit ngayon sipol na yung tunong... hay.. pleas help
    Baka compressor bearing. Have to hear it, though.
    May 2004
    napapalitan ba yung bearing lang o buong compressor? yung pulley ba may bearing din? kano un kung pallitan?
    thanks
    napapalitan yung bearing nang compressor. sa akin napalitan -P2,100 lang saka overhaul na din nang aircon sama linis.
    Oct 2004
    This looks like a job for MM (Mang Mario)...
    See thread below:
    http://tsikot.yehey.com/forums/showt...ght=mang+mario
    Or you can do a search for "Mang Mario" in the search box located in the upper-left hand corner and see a similar case just like your case in the search results...
    Sana nakatulong ako just like the people here always ready to help me on my own tsikot problems. :-)
    Oct 2003
    probably a grounded electrical humming to the speakers or the belt is too tight or too loose.
    Feb 2003
    when u hear the sound, try turning the aircon off (w windows down, so u can hear it),
    pag nawala, malamang sa bearing yyun.
    Sep 2004
    sa compressor nga yan. ganyan din sa kin. nilangisan lang. tatagal pa naman daw kahit 2 taon. pero maingay lang nga.
    there are two bearings that might be creating that "sipol" one is the compressor bearing like everyone said and the other one is the idler bearing. sa mga kotse lahat meron nito di ko lang sure sa SUV's , AUV's and trucks
    May 2004
    i had it estimated at an airshop near our place... sabi nung tumingin sa compressor daw.. possible bearing.. sa 3 shops ko pinatignan ganun diagnosis nila.. baka sa sat pa gawa ko na... la pa kse time eh... thanks mga peeps... sana mura lang gastos..
    Feb 2003
    punta ka na lang kay mang mario(?)
    aircon specialist
    malapit sa may SM north edsa. highly recommended po siya.
    Mura lang pag bearing, basta wag lang tatamaan yung shaft ng compressor.
    Oct 2007
    hi po... im also having the same experience, may whistling, at hindi lang basta whistling, super lakas na whistling.. a mechanic also told me na compressor yun.. he already overhauled it, changed the pulley bearing..ganun pa rin..so compressor nga raw talaga.. ano suggestions on what i should do? palitan ko nga ba ng compressor un? may alam po ba kayo malapit na aircon mechanic sa angono, rizal? east of metro manila.. tnx!!!!!!
    ako naman po meron din whistling sound...
    pero kahit wala akong aircon may tunog sya...
    hihina lang yung tunog pag bibitawan ko unti unti gas...
    sometimes naman walng tunog.
    hindi ko alam kung bakit.
    minumulto lang ba ako? napiplip?
    or kapareho lang nila sa compressor ang problem?
    I experience whistling sound in the Aircon. but the cause was just a leaf stuck on the aircon radiator. the sound actualy sounds good because it sounded like a plane's turbine, and was louder than our turbo.
    yup, compressor nga yan. have heard the same humming/whistling sound when i turn on my a/c, then nawawala pag off-on ko uli. now, nawawala na ang lamig. have to bring my car to denso for check up. malamang replace compressor ako.
    i have the same problem...my 93 gli corolla e whistling sound pero random ang paglabas nya.
    Pagtumatakbo ang oto minsan tutunog pag pinatay ko aircon nawawala, tapos pag on ko ulit aircon wala na..minsan naman pag tumunog e ire-rev ko lang nawawala din ..ang masama e ito...pag pinapatay ko makina me parang pahabol pa na sipol...
    ang tunog e sa bandang gitna ng makina... ito pala ang case ko...medyo 2 months na butas ang air filter hose ko pero tinape ko lang..sabi ng mekaniko e nadumihan daw yung intake na kinakabitan ng air filter hose...tapos isprayan ko lang daw ng "grease away" e kaso wala ako makita sa Ace hardware at sa handyman...san kaya ako makakabili nun at ano ang alternative kung walang available na "grease away"?
    madumi kaya ang fuel injector ko? ano kaya ang magandang panlinis para sa EFI?
    HELP po....naiinis na ko sa sipol na tunog na to...di po sya galing sa compressor ng aircon or sa ano mang belt or fan...
    thanks and more power
whistling sound when aircon is on and hi rev
