Results 21 to 30 of 34
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 16th, 2007 04:10 PM #22
September 16th, 2007 04:56 PM #24
for me, kung sobrang dumi na/kalawang, have your radiator overhaul.... then bago final, put cooling system flush run engine and re-flush with running water until all the acid comes out... use distilled water next time..
Tsikot Member Rank 5
- Nov 2003
- 3,849
September 16th, 2007 10:14 PM #25don't use turco... you won't be able to get it into the engine din naman since it is so thick.
clarify muna though what you see... may halong oil ba?
October 11th, 2007 07:58 PM #26
bosing,
san sa paranaque ang jp wheels? ang autotechnika? been trying to find a shop that has a lav'ra'mon machine for radiator and engine cooling system flushing.
when i used to own an 82 lancer box-type, had it cleaned in a radiator shop between edsa and libertad, and changed the radiator from a 2-column to a 3-column. not sure kung open pa sila.
paki pm ako sa tibo_3rd*yahoo.com.
thanks.
- Aug 2005
- 87
October 12th, 2007 01:26 PM #27sir kahit anong radiator cleaning di mawawala yan, i've experienced that before. Pag ganyan me problem na Cylinder head gasket, naghahalo na langis at tubig/coolant kaya nagkakaroon ng sediments. although kahit di kayo nago-overheat me tama na ng konti head, kaya yung sakin nung nagpalit kami cylinder head, pinalinis ko na rin ung dinadaanan ng tubig thru engine, then palit upper/lower hoses, overhaul radiator and palit reservoir din para sure.
upto now wala na yung parang putik sa radiator, prestone coolant gamit ko, yung wala ng halong tubig, pure coolant lang.
October 12th, 2007 06:09 PM #28
BANNED BANNED BANNED
- Aug 2007
- 999
October 12th, 2007 09:30 PM #29
- Jun 2006
- 2,605
I hope they improve the interior a bit. The current is IMHO low-rent for the price.
2025 Nissan Kicks
