Results 11 to 20 of 20
- Aug 2005
- 553
January 6th, 2014 04:25 PM #11Yes, but the coolant component will not evaporate until 179C. So what happens is that the radiator could be clogged, and it will build up pressure and push the coolant through the overflow pipe into the reservoir.
If the pressure is excessive, the reservoir fills up, a pressure cap somewhere pops, and then pushes out the coolant out of the reservoir but doesn't draw anything back in. That can explain the loss in the radiator while having a full reservoir.
- Sep 2013
- 153
January 23rd, 2014 05:56 PM #12Bought a surplus rad cap for 120 pesos. So far, ung dating takbo ko ng mga 10 to 15km na may nababawas na tubig sa rad agad ngayon parang ala na. Puno pa rin nung last na nacheck ko. Tumakbo ako ng mga 50km last saturday, and mukang ok pa din siya. Sana un na makaresolve ng problema ko sa waterloss. Just sharing.
- Aug 2005
- 553
January 28th, 2014 02:21 PM #13Likely when you opened your cap, you let out air, and then resealed your system.
The radiator overflow is normally the highest point in the loop and it will let air out first and then draw back coolant from the reservoir to replace the volume lost.
January 28th, 2014 02:25 PM #14
Habol sa tanung ng nauna nating ka tsikoteer..bro hindi ba tumataas temperature mo nung nag babawas kamu ng tubig ang radiator mo?
- Sep 2013
- 153
January 29th, 2014 09:23 AM #15
January 29th, 2014 02:15 PM #16
- Sep 2013
- 153
January 29th, 2014 04:44 PM #17
- Aug 2005
- 553
February 4th, 2014 06:14 PM #18A new cap is only P150 or so. I don't get it why you had to buy a surplus cap.
- Sep 2013
- 153
February 8th, 2014 05:22 PM #19
- Aug 2005
- 553
February 12th, 2014 06:04 PM #20The Circuit brand is a rebranded piece of junk from China.
There's a chance the sealing wasn't properly engaged.
So it's another case of "pwede na iyan" once again. It's that kind of thinking that will put...
