Results 1 to 10 of 25
May 30th, 2004 06:22 PM #1
hi guys,
meron leak yung radiator ng 2000 revo diesel ni erpats.. everyday naglalgay ng tubig (mga 1/3 liters) sa reservoir at so far hindi pa nag-overheat..
saan po ninyo ma-recommend ipa-check ito? sabi sa toyota casa eh 3 days iwan sa kanila at duda ako kung meron sila pang repair ng radiator, baka ipa subcontract lang nila sa labas..
actually, hindi ko makita kung saan yung leak, pero laging basa yung foam sa ilalim ng radiator , around 8K ata ang bago sa casa.
any recommended shops na okay at hindi taga maningil?
thanks
May 30th, 2004 07:03 PM #2
Lav Ra MOn daw sa may erodriguez near st lukes...plan to bring my PAJ also there
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 30th, 2004 09:41 PM #3you can call the shop and ask if may evercool na radiator for your car. probably half the price of the original unit and just as good kasi brand new. (7237625)
check mo narin yung drainplug ng rad mo kasi baka yun lang yung sira.
June 2nd, 2004 11:54 PM #4
thanks..
sige check ko muna drain plug..
wala pang 3 years yung radiator na ito, nung 2001 november ay pinalitan sa casa ng bago dahil nabangga ..
June 4th, 2004 08:03 PM #5
guys, meron pa po bang ibang suggestions dyan? ipa-check ko na ito tomorrow bago pa lumala.. thanks
- Dec 2009
- 1
December 22nd, 2009 11:29 PM #6gumagawa ako ng radiator kung leak lang ang problema mo gagastos kalang dyan ng 500 tanggal kabit nayun..dito location ko sa evangelista makati, 09206094938 text kalang saken, ang alam ko sa mga revo manipis ang hinang nyan sa mga hoses.. dun mdals nag kakaroon ng leak yan, check mo saang side napatak ang tubig..pag sa katawan mo nakita yung leak sa radaiator tube ang leak nyan..
December 23rd, 2009 10:37 AM #7
much better if you can replace with evercool just like speedyfix said, its better than having it selded and repaired, since kaya may leak yan eh dahil baka corroded na o rusty na yung loob. having it repaired is not a guarantee that it will not leak soon.
December 26th, 2009 04:08 PM #8
Mga Sir kapag malapit kayo dito sa location ng shop Punta lang kayo dito. Available brand new at Surplus Radiator.
We repair radiator, overhauling and convertion, Available Brass tank for replacement cracked Radiator plastic tank.
More Information
Ito address ng Shop namin
FERMIN Aircon, Electrical and Radiator Shop
1291-A Quirino Ave., San Dionisio Paranaque City
Tel # 8293771 or text 0915-5413610 / 0918-4314519
- Apr 2009
- 544
December 29th, 2009 02:59 PM #9hi .. how much new rad for crosswind 2001? and saan made?
yung radiator ko may leak sa kabitan ng hose sa upper. i'm thinking since matagal na rin palitan ko na.
thanks
high idle RPM at engine start
