Results 1 to 10 of 28
- Dec 2008
- 74
June 29th, 2017 06:36 PM #1Good pm mga bossing,
Ano po BA ang purpose Ng recirculate button? Medyo nalilito Kasi ako kung kailan Ko gagamitin Ito. Sabi Sa akin i-on Ko daw kapag pumapasok ang Amoy Ng usok Sa labas, tama po BA iyon? May nagsabi naman na kapag may umutot Sa loob Ng kotse eh i-on daw Ito, contradicting siya di BA?
At sabi Sa manual Ng kotse ay 10 minutes Lang daw i-on Ito at hirap ang AC at sasama ang FC.
Thank you po Sa mga sasagot!
- 54,286
June 29th, 2017 07:06 PM #3when the recirculate button is activated, vents from outside the front windshield open. air from the outside will enter the passenger cabin, and replace the old air with new air.
if the outside air is polluted, then the cabin air will also get polluted.
if the inside cabin air is foul-smelling, the outside air will replace this foul-smelling air.
if the outside air is hot, the aircon will have to work overtime, to cool the incoming hot air.
the manual said that??!!! are you sure?
June 29th, 2017 07:34 PM #5
The only times I don't use recirculate are:
1. When someone farts
2. When we are in an open area free from pollution
3. When a balikbayan insists to turn it off to get "fresh air" despite me saying "Oh, it's not fresh."
I noticed the a/c gets a little warmer with recirculate off.
- 54,286
June 29th, 2017 07:40 PM #6
- Dec 2008
- 74
June 29th, 2017 11:26 PM #7
- Jan 2013
- 1,851
June 29th, 2017 11:28 PM #8Isipin mo na lang bintana sya. Pag ON ang recirculate, sarado ang bintana. Pag OFF, binuksan mo ang bintana at makakapasok ang hangin galing sa labas. Makakalabas din ang hangin sa loob.
Sent from my ONEPLUS A3000 using Tapatalk
- Dec 2008
- 74
- Dec 2008
- 74
June 29th, 2017 11:39 PM #10
That makes sense. Higher elevation has lower atmospheric pressure and even if the cooling system is...
