Results 1 to 10 of 10
    How much are radiators now a days???? (civic esi)
    Replacement / surplus/ oem?
    I am not sure of the replacement specific for the Civic but I asked last month about a brand new replacement radiator for a Feroza that's made locally. It's priced around 7,000 pesos. Since the Civic radiator is smaller than the Feroza's if it's available then it should be cheaper. Try asking Sprint sa Banawe. Goodluck.
    thnks for the info... do u ahve the number of the shop?
    Dec 2002
    nmtin,
    Denso sells new and reconditioned radiators for most cars.
    Check with this dealer: Den-Aire inc, 545 quezon ave, west triangle. Tel 410-4515, 414-8785.
    denso also repairs orig plastic radiators.
    Denso Coolmate 8441493 Look for Mike Tagle, tell him David sent you and hingi ka discount....
    This is in Pasong Tamo BTW
    Unit 15&16 La Fuerza Bldg. 2241 Chino Roces Ave., Makati City
    cooldenso*pacific.net.ph
    The problem with mine kasi is that it has a hole in the body itself. I think this is because of rust na rin. My car is 7 years old na rin.
    I was just talking to mbt about my car, when I saw him in school and he said radiators last about 8 years lang daw, so I guess it had to happen
    not really, as long as your radiator doesn't have corrosion and mineral deposits, they can last a long, long time... our radiator in our maxima was orig for over 12 years...
    Dec 2002
    Yup, the radiator should last if you do proper maintenance.
    Use distilled water only, like "absolute" that comes in 5L containers and at least a 30% solution with a ethylene-glycol type coolant, like "peak".
    If rust caused the damage, then may be time to change the thermostat and hoses as well. I'd also change the radiator cap.
Radiator
