Results 41 to 45 of 45
April 29th, 2007 05:16 AM #41
Clearly, you didn't read it right. Tap water has minerals that will cause deposits/corrosion in the long run. Distilled water is required.
It would also be advisable to have a citric acid flush of the entire cooling system before filling it up with the desired water + coolant mixture. This rids the system of the corrosion and minerals left from the old cooling system.
April 29th, 2007 05:50 AM #42
- Aug 2003
- 9,720
May 1st, 2007 07:25 PM #43is there any way of manually opening up the thermostat to make sure all the water/coolant is drained? i tried draining and refilling it last weekend, napuno na siya after filling 3 liters
May 1st, 2007 09:24 PM #44
May 2nd, 2007 06:32 AM #45
Here in the US we open the heaters of the cars to allow the heat to also circulate through the heater hoses and heater core, allowing more coolant to get in and preventing air pockets to form. This allows less burping.
If your car is so equipped with the heaters, then you should run it as well.
Mas ok yung may easy access na cap. My Panasonic battery with i-stop (most of the time I missed to...
