This morning, on my way to the office, I noticed a whistling sound sa engine ko so I pulled over. Kita ko na tumatapon ang engine coolant ko so I immediately drove back to my house which is around 15 mins away. Pero on my way home, I turned the engine off and on several times kasi sobrang tumataas ang engine temp. It also came to the point that the temp gauge reached the red line.
After having it checked by my mevhanic, he found out that the lower radiator hose has a leak. I had it replaced right away and acording to him, the engine is running well naman. No signs of damage.
What other things should I check to know if my engine is indeed undamaged? As per my mechanic, one of the signs daw is that the water will overflow sa radiator pag sira ang internal parts. So far ok naman ang water circulation.
Advice din ni Otep is to change the oil since it may be burnt already due to overheating. I will do this first thing in the morning tomorrow.
Speedyfix,
Nakita na po ang culprit. It was because of a leak sa lower hose. Nagaalala po ako ngayon sa condition ng engine ko. How can I be sure that no internal damage occured???
Hindi sira ang internals pag bumubulwak ang tubig palabas ng radiator. Either barado ang radiator fins, engine water channels o raidator hose. Pag sira naman ang water pump, hindi iikot o dadaloy ang tubig pag sinilip sa butas ng radiator habang nasa 2000rpm ang makina. Kadalasan may leak ang water pump sa ilalim kung ito ay sira na.
Pwede rin palitan ang cylinder head gasket, karaniwan ito muna ang masisira dahil sa sobrang init ng makina bago pa magwarp ang cylinder head.
Kung may naririnig kang maingay na bakal na nagkikiskisan (mas maingay pa sa tunog ng makina), dun ka na mangamba na nasira ang internals mo.
i wouldn't worry about the condition of your engine just yet. try to drive it and see if nagbabawas coolant mo or if you start overheating again. if this starts happening again then i would suggest having the head gasket replaced, performing a crack test on the head and having it refaced
