Results 41 to 50 of 59
- Aug 2005
- 553
September 4th, 2012 12:41 PM #41
September 4th, 2012 01:14 PM #42
Costs will, however miniscule they can be -incrementally accrue
if the engine is lower than the normal operating temperature, i.e; 180-240 degrees fahrenheit, the electronic controlled transmission will not go to overdrive and there is no lock up mode of the torque converter clutch, the engine operates in open loop (not optimum fuel economy) and the emissions are higher than normal, that is HC and CO emissions. the engine needs more fuel to operate than when it is at normal operating temperatures. the pistons do not expand to their designed size and may have more blowby gases.
September 4th, 2012 02:43 PM #43
- Aug 2005
- 553
September 4th, 2012 03:16 PM #44If your engine is not running, and your fans are running, then there is obviously a waste of energy.
If your engine doesn't need the cooling, yet your fans are on full, then you are wasting energy.
As a consequence your battery life suffers as does your economy, however, incremental.
- Aug 2005
- 553
September 4th, 2012 03:41 PM #46
September 4th, 2012 03:42 PM #47
- Aug 2005
- 553
September 4th, 2012 03:43 PM #48It should be as is, switched on by the thermostat.
If your engine is hot, your fan would turn on as soon as you have your key position turned to ON anyway.
September 4th, 2012 03:47 PM #50
Xiaomi E-Car
