Results 1 to 10 of 17
- Nov 2005
- 311
November 17th, 2006 12:32 PM #1...happens to my Dad's Isuzu Highlander. Walang oil leak (or at least wala kami makita), hindi rin nagbabawas yung oil (and water) at yung takbo nung highlander oks naman, parang walang problem. But everytime we open the radiator cover ang daming oil na nakamix dun sa water. Ano po kaya ang problem? Any recommended talyer na expert on this?
TIA
November 17th, 2006 12:36 PM #2
Are you sure it's oil, and not rust? Oil does not mix in water. It stays on top and is immiscible.
- Nov 2005
- 311
November 17th, 2006 01:13 PM #3
November 17th, 2006 06:38 PM #4
Have your cylinder head gasket replaced ASAP. I'm quite sure that's the source of your problem.
Tsikot Member Rank 4
- Jun 2006
- 2,605
November 17th, 2006 07:50 PM #5+1 on cylinder head gasket. Get it checked by a reputable shop as soon as possible. baka lumala pa ang problema.
- 3,754
November 17th, 2006 08:09 PM #6baka mag sharon cuneta yan engine.. mag tubig at langis.. pa check mo na agad bago ka pa abutin ng overheat. or baka meron lang portion ng gasket na may leak pa try mo pa check ang higpit ng mga bolts
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 19th, 2006 02:23 PM #7better have the head checked narin by a machine shop kung derecho pa sya.
November 19th, 2006 04:40 PM #8
most likely the headgasket... pop your hood and take a look at it...
November 20th, 2006 07:15 AM #10
Baka naman po coolant lang ... may mga coolant kasi na pag luma na ay parang oil ang tingin natin.
I also prefer silver. hindi halata na madumi na and some imperfections like faded color and slight...
