Results 1 to 17 of 17
    Quote Originally Posted by mbeige View Post
    Are you sure it's oil, and not rust? Oil does not mix in water. It stays on top and is immiscible.
    it sure is oil. and let me correct myself, it's not (literraly) mixed with water but rather, i meant to say there are small amounts of oil in the radiator, together with the water.
    Sep 2004
    Have your cylinder head gasket replaced ASAP. I'm quite sure that's the source of your problem.
    Jun 2006
    +1 on cylinder head gasket. Get it checked by a reputable shop as soon as possible. baka lumala pa ang problema.
    baka mag sharon cuneta yan engine.. mag tubig at langis.. pa check mo na agad bago ka pa abutin ng overheat. or baka meron lang portion ng gasket na may leak pa try mo pa check ang higpit ng mga bolts
    Nov 2003
    better have the head checked narin by a machine shop kung derecho pa sya.
    Aug 2006
    most likely the headgasket... pop your hood and take a look at it...
    Sep 2006
    now you're learning....
Oil in the radiator
