Results 1 to 10 of 16
December 15th, 2010 07:12 PM #1
help po, I have problem with my radiator. kahit konting andar ko nauubos po yung water sa radiator, wala naman ako mapansin na tagas, never din ako nag overheat, ok din naman ang aircon ko. panay refil ako everytime aalis ako... and note na hindi naman nauubos or nababawasan man lang yung reserve water ko.. what could be the problem? help naman. thanks
honda esi
December 15th, 2010 07:21 PM #2
Check mo lang maiigi iyon lang ang sa tingin kong dahilan kung bakit nagbabawas ng tubig radiator mo pati iyong radiator hose mo baka worn out na at iyong hose clamp kalawangin na at importante iyong radiator cap mo kung sira na iyong goma at spring sa loob palitan mo na kaya lumalabas tubig sa radiator mo.
December 15th, 2010 07:28 PM #3
Check also your water pump. We've had this problem before on our old, high mileage cars and it was the water pump in two cases and the radiator in another.
With the water pump, check if there is water dripping while the car is running then nawawala when its shut off.
- Dec 2010
- 87
December 15th, 2010 07:47 PM #4ipa pressure test mo ang cooling system habang umaandar. dun lalabas ang leak nyan. Dun sa likod ng pulley ng water pump may butas yan na singawan ng init ng. Dun kadalasan tumatagas yan. Kung walang leak, check mo radiator cap baka hindi na nakaka hold ng pressure.
December 16th, 2010 10:10 PM #5
If there are no visible leaks anywhere in your cooling system, it could be that the water is seeping into the combustion chamber thru a bad head gasket or the head itself specially if you're blowing white smoke at the tail pipe.
December 17th, 2010 01:59 PM #6
check the freeze plugs on the engine block, they tend to corrode overtime and causes coolant leaks
December 22nd, 2010 06:45 PM #7
December 22nd, 2010 07:26 PM #8
If that only happens in the morning, it may just be condensation. But if even after driving a considerable distance ganun pa din, it may be connected with your original problem of coolant loss; the reasons already enumerated by our friends here. The best is to have a competent mechanic eliminate and repair all apparent defects starting from the simplest.
December 24th, 2010 12:54 PM #9
December 24th, 2010 03:29 PM #10
Not connected with the topic, but share ko na rin.
Last month, I had my rad fan and radiator itself cleaned and washed.
Tapos, pinalitan ko na yung rad hose ko .. yung luma kong rad hose, parang masisira na/worn out nung tinanggal so sabi ko buti nalang i decided to have these things replaced/cleaned.
Pati rad cap pinapalitan ko na rin.
Kaya from then, mas late yung pagtaas ng temp ko kaysa before. Hehehe.
Check mo din rad hose mo sir, baka sira na din eh.
Xiaomi E-Car
