Quote Originally Posted by redhorse22 View Post
Mga paps good day! Meron lang akong konting problem sa L300 namin.
Ung L300 namin mejo matagal na almost 10 years na, ngayon lang nagkaproblem sa temperature. Everytime na traffic e tumataas yung temp, this is pag naka aircon lang, pag patay yung aircon is bumabalik sya sa 1/2 ng gauge, other thing is when i was on SCTEX going to subic pag ang takbo ko is more 100 km/h same thing tumataas din ang temp at pag nakaaircon lang.
What do you think is causing this?
mga napagawa ko na
-pina silicone ang clutch fan
-changed water pump
-no leaks
-hinde din nababawasan ang coolant sa radiator
-change rad cap na din
-pina compression test ko din yung engine ok din yung results
Thanks in advance
+1 sir pa overhaul na po un radiator mo. if years na po since the last time kayo nagpalinis ng radiator cguro po its about time to clean/overhaul it again.yan po muna ang pinaka mura na dapat ipagawa sa engine cooling system. halos nagawa mo na po un mga basics tulad ng silicon sa engine fan clutch.. change ng water pump and rad cap... suggest ko din after mo pa overhaul try to remove the thermostat then observe lang po muna un behavior ng engine cooling system. if nawala un abnormal high temp gauge reading then decide if you must return the thermostat.
sir additional question lang. san po kayo nag pa compression check ng L300 FB nyo ?
