Results 11 to 20 of 40
January 30th, 2009 09:50 AM #11
Malakas ka siguro mag thermostat at patay agad pagdating sa destination, ganun rin KASI gawa dyan nung nasa planta pa lang, todo dito todo dun. I suggest gawing habit ang thermostat off (a/c button) with fan on few minutes before shutting down para matuyo ang linya. Maalis yan and would also help your battery for the next start.
Nung brand new XTO ko ganyan rin – amoy pawis na panis :doh: ke bago-bago. ganun lang ginawa ko, ambango na ngayon – 7 years without cleaning with only 30+K kms.
also stay away from gel air freshner esp yung mga citrus - umaasim amoy nyan pag tagal.
CHECK NA LANG PO SEARCH BUTTON, dami na discussion about this.Last edited by XTO; January 30th, 2009 at 09:53 AM.
January 30th, 2009 10:13 AM #12
ah thermostat pala (compressor na sinasabi ko)..
actually sir nabasa ko na yung nasa ibang thread...
ginagawa ko na rin yung mga suggestion dun na i off yung thermostat at i on lang yung fan pag malapit na...
saka hindi rin po ako malakas mag thermostat... 1-2 clicks lang oks na sa akin... fan ko 1-2 lang din lagi...
di rin po ako nag gel air freshner...
sensya na kung dito ko na post... ito kc yung nakaup na thread regarding aircons eh heheheh
- Apr 2008
- 7
February 4th, 2009 01:10 PM #13Have the same air con problem with my FD Civic, just got my unit last October. Mabaho talaga pag umaga. Nakakainis na minsan. Will try out the solutions suggested.
February 13th, 2009 03:26 AM #14
sir, i suggest kapag e switch on n po ung a/c mag open po kayo ng window para makasingaw ang bad odor or use lysol antibac... ang cause po ng bad odor e ung mga bagay n new like rubber matting or plastic.... nag kakaron po kc ng reaction s evaporator coil, n dikit po kc ang amoy s evaporator,...
February 14th, 2009 07:13 PM #15
- Jul 2010
- 2
April 4th, 2011 03:16 PM #17
April 21st, 2011 11:24 AM #18
We have this 2008 Toyota Innova and whenever we turn on the aircon (naka park whether indoor or outdoor), may parang panis na amoy na lumalabas sa vents. Sabi daw ng mom ko dahil sa mga perfume na nakalagay sa car. Can this be true?? Thanks!
April 21st, 2011 12:49 PM #19
It's possible. Perfume is based on natural scent oils and these can stick to certain surfaces (including the ducting of the A/C vents). As these oils age or react with bacteria/fungus, they can start smelling bad.
You can have the A/C cleaned and maybe the vents as well. Sometimes the A/C evaporator gets dirty and have fungi growing on it or dirty water accumulates there too. Cleaning should help there too.
- Apr 2011
- 11
April 22nd, 2011 05:20 AM #20me too i want to learn where the suction evaporator is, its to risk to guesting baka mali ang magawa ko im new also thank you in advanced...
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
