Results 1 to 10 of 34
- Oct 2004
- 58
September 13th, 2005 06:53 AM #1guys everyday nagbabawas ride ko ng coolant sa reserve tank wala nman leak.any idea posible problem?2002 revo
September 13th, 2005 09:40 AM #3
crack cylinder head gasket? but look into the "cheaper" repair first.
- Sep 2005
- 103
September 13th, 2005 01:12 PM #5
Check First:
- Radiator cap (change every 3 years dapat), you can only see the leaks on this if the engine is running and hot.
- busted water pump (water drains only when the engine is running)
- air pockets in the radiator?
- loose hose clamping
- Feb 2005
- 46
- Sep 2005
- 103
Tsikot Member Rank 5
- Nov 2003
- 3,848
- Oct 2004
- 58
September 17th, 2005 07:03 PM #10tnx guy,ok pa fan and d pa naman nag over heat.n pansin ko pagdating ko na bahay sa gabi check ko wala naman bawas but pag check next morning laki ng bawas sa reserve tank.any idea why?
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
