Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
    #31
    tama ang suggestions ni speedyfix ,meron lang ako suggestion , sa pressure test if there is no vissible leak, try mo sa computerized 5 gas engine annalysis walang lusot yan,the machine will be able to detect the rootcause of your problem
    #32
    ask ko lang if may nakagamit na sa inyo ng alumaseal radiator stop leak or quaker city radiator stop leak or any stop leak product? may leak yung rear plate ng cylinder block ko eh in between the engine block and transmission. it's a plate that separates coolant from the engine block to the transmission system. (ito yung initial diagnosis nung mechanic kanina pagsilip nya sa baba ng engine block, may leak ng coolant sa dulo ng oil pan gasket, between the engine and transmission.) option ko is to drop down the transmission to have that plate replaced, or use this stop leak product? ganon ka-complicated yung procedure ba talaga? any insights? magkakaproblem ba transmission ko non pag binaba? automatic yung akin eh sayang naman kasi ang ganda pa ng transmission ko now.
    #33
    #34
    double post, mods padelete nalang nung duplicate
losing coolant.. slowly.. [merged]
