Results 1 to 6 of 6
- Oct 2009
- 9
November 1st, 2009 09:37 AM #1After kong magflush ng radiator and putting distilled+coolant.Npansin ko may pumapatak sa garage na water.
Nacheck ko na lahat hose up and down pero nung sinilip ko sa ilalim dun sa malapit sa may drain plug pumapatak water. Dun sa parang butas near the plug..
Im observing til now pero di nababawasan reservoir ko and sa radiator...pero may patak pa din sa ilalim...Replace ko na sana radiator ko with evercool pero weird di nagbabawas ng water.Normal temp ko 1/3 di nagbabago
My ride is civic 97 manual.Thanks
- 34
November 1st, 2009 11:23 AM #2baka maluwag. Kung mahigpit naman, icheck at palitan mo yung o-ring or gasket nya di na nagsesealed ng maayos yan or palitan mo yung buong drain plug, mura lang yan.
- Oct 2009
- 9
November 2nd, 2009 01:17 PM #3Ok sir try ko hanap drain plug later,nagbabawas pala sa reservoir,konti di masyadong pansinin kaya akala ko di nagbabawas.
Pero kaninang morning mejo marami na nagleak sa flooring ng garage though di masyado sa reservoir and ok naman water sa radiator...
- Nov 2009
- 4
November 16th, 2009 08:47 PM #4Hmmm. It's not that important I guess since reservoir is excess or steam from the radiator. Minsan bumabalik din sa system pero most of the time it doesn't and algae just builds up. In my case I used a PCV or check valve. Small valve not to get that dirty algae infested water back in the system. But if reservoir is clean and you want it recycled you can try just using epoxy or sealants to seal it. There is no real pressure in the reservoir so any sealant should work.
- Oct 2009
- 9
November 17th, 2009 12:54 PM #5I found out na yung culprit,dun sa plastic top nag rad, nakakaita kasi ako ng coolant one morning..but i observed na ok naman water level ko sa reservoir and dun sa rad...Palitan ko na dapat rad ko mga sir?kesa pagawa yung stock ng honda?
November 17th, 2009 01:00 PM #6
pagnasabudget pwede ka palit na ng rad, kung wala naman meron sa mga commercial kaya ang pressure ng rad parang GLADRIATOR tanong mo na lang sa hardware or use steel epoxy.
Good thing you don't have an oil pressure gauge. It'll make you think twice about going 50.
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
