Results 1 to 10 of 13
July 22nd, 2015 10:33 PM #1
My Pajero CK has a leaking AC. The area under the glove compartment is now always wet because of this and when I turn, I can hear a spraying sound from the glove compartment area. What could be the problem and where can I take it to in the Banawe area?
July 22nd, 2015 10:41 PM #2
July 22nd, 2015 10:48 PM #3
- May 2012
- 46
July 23rd, 2015 02:57 AM #4Try to check the drain hose, it may just be clogged. Simply poke it with a stick to check if it is.
July 23rd, 2015 05:30 AM #5
July 23rd, 2015 09:50 AM #7
July 23rd, 2015 12:41 PM #8
July 23rd, 2015 12:44 PM #10
Yep. The drain hose is connected to the evaporator behind the glove compartment, passes through a grommet in the firewall, and ends a few inches after that. It's usually the only hose in the engine compartment that's not connected to anything else. If you find more then you've got other problems
Monk-owned R53
