Results 11 to 13 of 13
- Jan 2008
- 4,726
June 18th, 2008 09:10 PM #11we also have a mitsubishi l300 exceed long body (local cbu japan) same with 4D56 engine but never experienced over heating problem.. pati sa loob hindi gumagapang yung init ng engine kaya hindi maluluto balls mo... matibay din everyday use walang reklamo ang vehicle...
converted mitsu exceed ba yan?? or local??
yung engine cooling fan mo maybe needs silicone gel refill para maging makapit ulit... also check mo yung radiator fins for possible dirt accumulation...
yung fan pwede mo din DIY yan if you have the proper tools... mahigpit kasi yung bolts nyan so you will be needing a impact driver.. once removed mo na yung fan linisin mo lang yung loob nung casing then refill mo nung silicone gel.. then assemble ulit ok na yan.. make sure na walang leaks yung housing kasi mauubos lang ulet yung oil in the long run.. pwede mo din i-fix yan but may negative effects like higher FC, poor power and may damage your water pump
- 7
June 20th, 2008 10:42 AM #12Yapoy,
It's also CBU and released locally. We purchased it back in 98. But it's gasoline fed. Medyo malakas sa gas. 2.0 ang engine.
Fan has been fixed! Glad to report that the van didn't over heat during my test drive yesterday. Temperature never went beyond 3/8 of the meter.
Thanks for all the help!
- Jul 2013
- 7
August 10th, 2013 09:36 AM #13ganyan din po sa kin naglagay po ako ng silicon oil sa fan ok na po cya hindi na free wheeling fan
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
