Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    Oct 2011
    The manual system has less moving parts, less stuff to go wrong.
    yes, of course. I think pati ung remote radio control kasama rin sa facelift.
    Nagkaron na din ng AUX jack after facelift.
    Apr 2005
    I'm not sure what you mean by "on/off" of the compressor. But, on a standstill idle w/ ac on, from time to time, you will notice the tachometer go up by 200rpm or less for a second or two then go down. I believe this has something to do with the compressor.
    Sa mga regular type of aircon yung compressor will shut of (magnetic clutch) once na attain na yung temperature setting ng thermostat. Pag tumaas na ang temperature the magnetic clutch will engage again para gumana ang compressor. The same with aircon sa mga bahay namamatay ang compressor.
    Oct 2011
    AUX jack? saan yan?
    Oct 2011
    Quote Originally Posted by SEALANDER View Post
    yes, ganon ang function ng conventional type of A/C on and off. I wonder kung magkaroon ng invertype aircon ang Innova?
    Apr 2005
    Pag naka auto mode ganun pa din kaya?
    Dec 2014
    Hi All,
    I am a new owner of Innova G with auto climate AC, first car ko din ito so wala ako kaalam alam sa sasakyan, first byahe ko may nadaanan akong mausok na kalsada, normal lang po ba na maamoy sa loob ng sasakyan yun kahit sarado lahat ng bintana o may kailangang pindutin sa AC?
    Oct 2013
    Quote Originally Posted by dhey View Post
    Hi All,
    congratz sir on your first car, read the user's manual first just like what TS did, if still confusing or the answer is not there then further pursue your inquiry here...
    drive safe
    Hi All,
    Bro ilagay mo lang sya sa recirculation mode setting
    Yes. Switch to recirculate mode so outside air will not be admitted into the cabin.
Innova G automatic climate control
