Results 1 to 10 of 36
October 1st, 2013 11:35 AM #1
Ganito kasi nangyari, i consult ko na din dito.
Two months ago, nagpalit ako ng radiator (Hyundai Getz 1.1, 07 Model), dahil sa overheat. Everything was checked from the water pump, to the thermostat to the radiator fans so the cause of overheat was determined to be na nasa radiator nga.
So far, nawala ang overheating concerns. Kaya lang napapasin ko na yung radiator losses significant amount of coolant wherein kailangan ko mag top up ng around 1/4 liter every week.
Tried looking for leaks, wala naman. Tried checking kung may nagmimix na coolant sa oil, wala naman. Wala ring smoke.
Walang kulo yung reservoir and hindi nababawasan yung coolant sa reservoir.
Nagpalit na din ako ng radiator cap two weeks ago.
Ano kaya reason neto? Is this normal? I don't think so dahil dun sa luma kong radiator and dun sa other cars ko, i seldom top up. Saan napupunta yung coolant?
Wala naman akong issue, kaya lang, dito sa oto kong ito, eto yung parati kong chinecheck ang radiator coolant level.
- Apr 2010
- 742
October 1st, 2013 11:48 AM #2Check the connections of the rad hoses, probably nung binalik eh hindi na maganda yung pagka fit.
Or there's a pinhole leak in the new radiator, ask someone to rev and look at the radiator and its hoses
October 1st, 2013 11:48 AM #3
Di tumataas yung level sa reservoir?
Try checking your bypass hoses also to see if there are any leaks that might be hitting hot parts of the engine (thus evaporating the coolant). Magpa-compression test ka rin to remove any possibility of engine problems.
October 1st, 2013 12:01 PM #4
On my old Lancer the culprit was the hose that bypasses the engine block to cabin heater route. This is usually located between the engine and the firewall so a pinhole there is kinda hard to see. Buti na lang puro kalawang radiator ko non kaya the rust trail led me to it
Check the hoses going to the TB also.
October 1st, 2013 02:20 PM #5
October 1st, 2013 02:49 PM #6
nilagyan ba sir ng silicone gasket maker yung hose nung binalik nila or plain hose and clip lang?
October 1st, 2013 02:54 PM #7
October 1st, 2013 04:24 PM #8
- Dec 2012
- 304
October 2nd, 2013 11:03 AM #9
sorry 1D4LV, i don't want to hi jack your thread, may question lang kay sir JohnM
sir JohnM, I observed something similar sa sentra ko. may maliit na hole sa fire wall, engine side, na nagdidrip yung water kaya nauubos yung coolant reserve ko. Anong naging solution sa Lancer nyo sir? thanks.
October 2nd, 2013 11:12 AM #10
VinFast VF 3
