Results 21 to 30 of 36
October 7th, 2013 12:43 PM #21
Has been discussed before. Basically a bad idea to remove the thermostat. Takes longer to warm up so increases fuel consumption on cold starts. Risk of overheat at high revs because the coolant is traveling too fast through the radiator giving it no chance to vent its heat.
October 7th, 2013 12:48 PM #22
No. Ang laking bagay ng thermostat. Ang masama lang sa thermostat, pag busted ito at hindi bumukas, panigurado ang overheat nito. Mura lang naman thermostat eh. Yan ang magmamaintain ng normal operating temperature ng sasakyan mo. Tsaka pag wala thermostat, matagal bago uminit yun makina.
1D4LV, sir, kung sakali kasi thermostat yan, depende kasi kung paano siya na-busted. Either hindi na siya bumukas o hindi na sumara. Kung hindi yan bumukas, magkakaroon pa rin ng loos of water/coolant tapos mabilis uminit yun sasakyan. Kung sakali na hindi naman sumara, tuloy lang circulation ng tubig tapos ang engine temperature mo ay hindi aabot sa normal operating temperature. Have it checked na rin para ma-eliminate natin yun problema sa thermostat.
October 7th, 2013 12:55 PM #23
thanks bro.... based sa sinabi mo, malamang thermostat. dati, medyo inaabot ako ng 3-5 minutes bago ko marating ang optimal temperature, ngayon, mga 1 minute lang.
i have also checked the hard starting issue with the supposed to be thermostat problem and i quote
"Test the coolant temperature sensor. What happens is when these go bad, they either cause the car not to get enough fuel when cold to getting to much fuel when the car is hot."
Is the coolant temperature sensor the same as the thermostat? I think so.... If yes, could this hold logic na talagang thermostat and problem?
October 7th, 2013 12:57 PM #24
October 7th, 2013 01:02 PM #25
Nope. The thermostat is a valve with springs that opens and closes depending on the coolant temp. The coolant sensor is usually located near the thermostat housing but it could also be somewhere else on the block.
On cold starts the temp sensor signals the ECU to run a bit rich to aid starting. When the coolant temp increases it dials down the fuel accordingly.
October 7th, 2013 01:05 PM #26
October 7th, 2013 02:09 PM #27
October 7th, 2013 02:13 PM #28
Possible. The thermostat is easy to check. Just take it out and put it in boiling water. If it opens it's still ok. It should close when put in warm water. The sensor however requires an electrical test. A sensor for your engine might be available in the surplus shops.
Nga pala what do you mean when you said na pumutok ang housing ng thermostat? Kinalawang then hininang na lang?Last edited by JohnM; October 7th, 2013 at 02:21 PM.
October 7th, 2013 02:32 PM #29
