Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
    Jun 2015
    #21
    check niyo din mga hose niyo sir baka may leaks
    Aug 2015
    #22
    Anyone can help me decide or ano po ba recommended bar rating ng radiator cap ng honda Crv gen 1 with a b20z engine. Im currently at 1.1 pero kabado po ako sa radiator crack. But .9 bar nauubos yung coolant causing air to accumulate making the temp guage fluctuate pag napuno ng hangin yung system. New honda user po ako so any honda crv experieinced user insights would be much appreciated.
    Jun 2015
    #23
    Ganyan din naging kaso ng auto ko sir nireplace ko lang rad cap tapos overhaual radiator and all is good na.
    Oct 2015
    #24
    sir ganyan din ako tumataas temp abot pa ng 3/4 ginawa ko overhaul radiator palit ng cap nya,,,then pinagana ko yung isang fan kasi dinag oautomatic radiator fan nya...
    help nrin ako....pag ginamit ko naman auto ko pag long drive ...nagbabawas ng tubig,,,sayang yung coolant ko...
    pag nakalimutan mo lagyan ayun overheat...ano kaya gagawin...top overhaul po ba to..
    Oct 2015
    #25
    #26
    Quote Originally Posted by burstcruiser View Post
    yung kulay ng fluid sa radiator mo, ano kulay? pag nag brown, milky brown, naghahalo ang langis sa coolant, overhaul na yan.
    kung nagbabawas lang without your coolant changing color, there could be a leak somewhere.
    #27
    May 2009
    #28
    o baka isang kaso na naman iyan ng "missing thermostat" brader....icheck mo muna kung meron o wala lalu na kung hindi ikaw ang 1st owner
    Oct 2015
    #29
    Quote Originally Posted by 1D4LV View Post
    Thanks sir...
    check ko bukas...
    Oct 2015
    #30
    Thanks sir...
    check ko bukas...
    Oct 2015
    #31
    Quote Originally Posted by miked View Post
    check ko bukas sir...
    as ko na rin ano ang best brand ng sparkplug.
    Oct 2015
    #32
    #33
    use NGK.... but make sure its original.
    #34
    #35
    temp gauge only reach 2nd bar level. tapos saka palang aandar ang rad fan. rad already overhauled and change thermo switch and sender unit. aandar ang fan for around 1 minute then off again for 1.30 to 2 minutes. ano kaya problema nito? papano macheck kung hindi busted and temp gauge? hindi ko pa kasi nakita na tumaas ito ng 3rd bar level.
Help: Overheating Problem
