check niyo din mga hose niyo sir baka may leaks
Anyone can help me decide or ano po ba recommended bar rating ng radiator cap ng honda Crv gen 1 with a b20z engine. Im currently at 1.1 pero kabado po ako sa radiator crack. But .9 bar nauubos yung coolant causing air to accumulate making the temp guage fluctuate pag napuno ng hangin yung system. New honda user po ako so any honda crv experieinced user insights would be much appreciated.
Ganyan din naging kaso ng auto ko sir nireplace ko lang rad cap tapos overhaual radiator and all is good na.
sir ganyan din ako tumataas temp abot pa ng 3/4 ginawa ko overhaul radiator palit ng cap nya,,,then pinagana ko yung isang fan kasi dinag oautomatic radiator fan nya...
help nrin ako....pag ginamit ko naman auto ko pag long drive ...nagbabawas ng tubig,,,sayang yung coolant ko...
pag nakalimutan mo lagyan ayun overheat...ano kaya gagawin...top overhaul po ba to..
temp gauge only reach 2nd bar level. tapos saka palang aandar ang rad fan. rad already overhauled and change thermo switch and sender unit. aandar ang fan for around 1 minute then off again for 1.30 to 2 minutes. ano kaya problema nito? papano macheck kung hindi busted and temp gauge? hindi ko pa kasi nakita na tumaas ito ng 3rd bar level.
