Results 11 to 20 of 35
- 52,514
May 16th, 2015 12:55 PM #11- - - - - - - - - - - - - - - - - - - - - -
when i bought my korean van brand new, the temp needle never got higher than 1/2. as it got older over the years, the needle started creeping up and up.. probably because the scales were starting to build up.. old school ako.. plain water only for coolant.).
finally, i decided to upgrade the radiator with one having more rows than factory.. ayun.. ok na ulit..
and that shroud is important.. in close engine quarters and in non-moving traffic, it does prevent "recycling" the hot air..Last edited by dr. d; May 16th, 2015 at 01:05 PM.
May 16th, 2015 03:13 PM #12
Remember that radiator descaling service called LAVRAMON? Very effective in cleaning up the scales in the engine block & radiator. Meron pa ba nun?
May 16th, 2015 04:49 PM #13
May 16th, 2015 06:35 PM #14
May 30th, 2015 07:12 PM #15
Mga sir para saan po ba itong mga hose na nasaraduhan? Pang dual radiator po ba?
- Jul 2012
- 345
July 22nd, 2015 01:16 PM #16mga sir kakapalit ko lang ng rad kasi may tama na at leaks yung lumang rad. ok nmn so far pero pansin ng mechanic ko na yung fan hindi nag on unless nka on aircon tapos matagal interval bago umikot ulit yung fan. sabi nya regardless kung nka aircon or hindi dapat iikot fan kpg mainit na coolant. palitan ko na daw thermostat sensor at thermo switch. honda jazz 2005 automatic po ride ko.. what you think? honestly never ko tlga narinig umikot fans kapag off aircon.. akala ko normal lang un.
- Jul 2012
- 345
July 22nd, 2015 08:52 PM #17after a few hours of travel i checked the water.. mejo bumaba.. nag lagay pako ulit. will wait lumamig ulit then check water level sa rad.
July 26th, 2015 12:35 PM #18
Sir sotel, the hoses you are referring to are for the heater coil for the ac.
- Jun 2015
- 11
July 30th, 2015 03:43 PM #19Agree ako sir wiring at sensor pacheck ninyo. sure ba kayo na wala kayong leaks?
- Jun 2015
- 11
July 30th, 2015 03:44 PM #20Agree ako sir pacheck niyo na sensor and wirings, tapos pacheck niyo na din kung may leaks kayo sa cooling system niyo.
Traffic!
