Quote Originally Posted by drifterx View Post
Patulong naman po mga master umiinit kasi yung pajero ko 2.5 tdic 4d56 na makina. Ang sama lang eh hindi ko makita kung umiinit siya kasi sira yung gauge what happens is everytime gamitin ko siya isang tabo ang nawawala tapos yung reservoir ko napupuno. Weird pa nun hindi naman umaapaw yung reservoir kasi tuyo yung paligid nya. I think water pump is still fine as I kept the motor running with the cap off sa radiator and water is moving, hindi rin bumubulwak pag inistart ko na. This happens with or without the aircon on and started after I got my aircon fixed. The aux fan for the aircon is working naman. No signs of water leaks. The thermostat has already been removed.
Here is what got done:
- Radiator overhauled.
- Replaced radiator cap.
Why was the radiator overhauled? 1992? Bata pa ito by my standards.
Are you one of those guys who uses water only on their cooling system?
Did you replace your radiator cap with Oem radiator cap?
Mga suggestions ng mekaniko ko:
- Wire the aircon aux fan to run all the time
- If the first suggestion fails top overhaul na raw to replace the master head gasket.
-Mali yon i rekta aux fan. Hindi ito dapat ginagawa ng auto elect. Find one.
-Paano sya nakarating sa conclusion na sira head casket? Nag compression test ba siya?
Medyo alangan ako dun sa unang suggestion as I feel its more of a quick fix than the cure. Ano pa po kaya ang namimiss ko? Meron pa ba ako dapat icheck? Could it be that the water pump is working but not enough?
Yon bang (reservior) expansion tank mo madumi at me putik sa ilalim?
Any input is greatly appreciated salamat po.
