Patulong naman po mga master umiinit kasi yung pajero ko 2.5 tdic 4d56 na makina. Ang sama lang eh hindi ko makita kung umiinit siya kasi sira yung gauge what happens is everytime gamitin ko siya isang tabo ang nawawala tapos yung reservoir ko napupuno. Weird pa nun hindi naman umaapaw yung reservoir kasi tuyo yung paligid nya. I think water pump is still fine as I kept the motor running with the cap off sa radiator and water is moving, hindi rin bumubulwak pag inistart ko na. This happens with or without the aircon on and started after I got my aircon fixed. The aux fan for the aircon is working naman. No signs of water leaks. The thermostat has already been removed.
Here is what got done:
- Radiator overhauled.
- Replaced radiator cap.
Mga suggestions ng mekaniko ko:
- Wire the aircon aux fan to run all the time
- If the first suggestion fails top overhaul na raw to replace the master head gasket.
Medyo alangan ako dun sa unang suggestion as I feel its more of a quick fix than the cure. Ano pa po kaya ang namimiss ko? Meron pa ba ako dapat icheck? Could it be that the water pump is working but not enough?
